Not sure sure if it’s supported.
I have a scene with custom editing forest items placed.
Tried to adjust the Forest Pack Materials but nothing is being updated within Vantage. I can see the adjustments in the view port.
Any suggestion as to what I am doing wrong? Thank you.
I should add that I can work with it somewhat directly in the ForestColor if I pick a submaterial, but it doesn’t seen to work from the Forest Pack rollout.
Is it possible to record a short video of what you are doing that doesn’t cause a proper update ?
An example scene will also be very helpful.
Greetings,
Vladimir Nedev
i might need a little time but I’ll try to get something to yhou. Btw I’m old school so I actually still feel more comfortable with the Compact Editor vs. Slate.
