I've found bug when saving vrmeshes
create folder on drive c called for example “work”. In “work” create folder “vrmesh”. now try to save vrmesh in this folder :slight_smile: Somehow it’s creating file “vrmesName.vrmesh” instead of putting name.vrmesh in this directory.
Thanks for the pointer, will look into it. It will probably work if you use something else as the folder name, instead of “vrmesh”
yep it works fine with other names but I keep my vrmeshes in vrmesh folder :slight_smile: so I need to rename and then in asset browser repath it :slight_smile:
