Jagged Edges in Render
I’m not able to figure out why these jagged edges are showing up on my rounded off objects. I used round corner to round off the basin slab, shutters and more.
I rendered the file on RTX mode since I have an RTX Graphics card.
Hi @manishpaul_simon
Kindly note that the issue occurs because the 1_bathroom tile material is applied to the whole group.
If you select the group and change the material to the default one (from the Entity panel), everything should render as expected.
Thanks for your reply. Will check that out today and see if it works.
