It’s happening in multiple different cameras/angles also.
Assumed may have been a camera issue but seems directly related to the lighting or materials.
See screenshot attached for light pixelation in another area of the environment.
Seems to only be pixelated on the cabinetry, not the floor.
Would this signal a material issue.
Also it only seems to do it when rendering the final render. When using the corona IR it does not happen everytime
Ok so after alot of testing the jagged shadow edges seem to be a material issue.
When I disable the reflection completely in the corona material the jagged edges smooths out and goes away.
See below for noisy result but no jagged edges once reflection channel is turned off.
However this results in unrealistic reflections. Any amount, even .01 of reflection causes this jagged edge.
Probably need to know more about the scene - does the material have Glossiness of less than 1? (Ah I see that it does - what happens with Glossiness of 1?) Is the light coming in through glass, or directly onto the material? Does changing either of those make a difference? What is the light, a Corona Sun?
Have tried different glossiness levels and still get the jagged edge when any amount of reflection is enabled.
Only way to avoid is disable reflection channel completely (untick)
To me this looks like an issue with the normals of the cabinet.
See if you can try a different normal angle for the cabinets, and or cleaner geometry for it, if it’s triangulated.
Thanks. I’d also like to add that we have had similar cases reported for artifacts that look similar to yours (C4D & Max). It’s unsure at this point if they are all related. With that said, the issue is in an ongoing investigation which we hope to resolve.
