Please don’t link other threads just to say their is no fix!.. the Enscape team has done a tremendous job with improvements over the years! And it does seem that each new version and even preview versions are getting better and better… but an issue that has NEVER EVER been fixed is the horrible Jagged Edges in shadows!.. no other real time rendering program does that.. you’d think softening shadows would don it but it does nothing.. all shadows coming from light source look like a chain saw!!! the natural light from sun has improved immensely and looks spectacular! but all non natural lighting from any light source is very jagged and looks sloppy! wouldn’t the easiest fix just be to simply have the light be in the simple shape of what ever the light source is? you guys are brilliant coders and have alot of experience! PLEASE FIX!!! Also can you PLEASE make the light source you actually call a sphere an actual sphere? please! that would probably help with the jagged edges as well! THANK YOU!
can you show an example, I’ve never seen any jagged shadows in my renders. What’s your primary app? SketchUp?, Revit? Etc
Thanks for your message!
It would be great to get some examples indeed - which CAD solution are you using with Enscape? I’m mainly asking for some examples which can then act as feedback which I can better forward to our developers, so thanks a lot in advance!
i had something similar with a out door bollard but I realised that this ISNT the real world so real ‘like’ lights won’t always work.
What you have in your 1st image is the housing of the fixture is casting the shadow top and bottom, the answer is to remove the Enscape light from within the model and try 2 outside of it pointing up and down. This way you’ll get the effect of the light but without the shadow.
its not the housing.. the cylinder sconce is as circular as any circle is and is smoothed… the lighting issues happens with ALL “Enscape Lighting Objects”!! The way they cast shadows has always been extremely jagged.. with all the updates Enscape has done over the years you’d think they’d be able to fix a problem that has been present since they originally founded this program… shadows from sun has been tremendously improved… but shadows from their OWN Lighting Objects Are Very Low Resolution as they are always extremely Jagged!!!
We have a request on our agenda already to provide even higher quality shadow maps but be aware that this would also require a lot more performance, which is why we settled with a resolution that should suffice for most users, on most machines. The topic got your upvote though of course.
Still, I will bring this subject up again in our next Developer meeting, to see what can be down from a technical standpoint in the future. Your feedback has been forwarded as well! ![]()
Demian Gutberlet Thank you soo much! How about instead of making it standard.. how about making it where people can simply choose a resolution for the shadows of “Enscape Object Lighting"for example Low-Medium-High option inside of the Enscape Objects Tab? I believe giving us options like that will make people like with me with high end pc (Rtx 3090, i9 9900k, 64 GB of Ram, 3TB SSD, 38” Alienware AW3821DW 3840p x 1600p monitor) ?
best, 8) 8) 8) ![]()
Thanks @ThatOneArchie_vXv
We’ll bring it up.
Thank you Kaj another thing if i haven’t mentioned it can you please offer us a DarkMode feature? itd be nice to have whole Enscape interface dark or atleast an option…
hopefully the entire enscape team had a wonderful christmas!
Thank you @ThatOneArchie_vXv , we hope you and your loved ones had a safe and joyful Christmas as well!
Dark Mode is on the list, I’ve added your vote.
I think being able to choose shadow map size would be great. i also have a horrible case of the jaggeds
