Latest JBL speaker. The woofer
Not that accurate - only two photos + front print, but… I like it
40min.
10.5
textures - generated in Genetica (not for closeups, you know)
one Vray light + hdri
BTW - this time Vray for Rhino bugs weren’t that annoying
JBL no.1
Nice.
Small suggestions:
- I miss a fillet on the big metal ring, it looks so sharp.
- The HDRI looks like the classical kitchen HDRI - did you change the gamma of the HDRI befor from gamma 1 to gamma 2.2 befor? The lighting gamma looks not right.
- I would use a small gap between the ground and the metal foots like the gap between the wood housing and the foots. The foot-ground area looks to blury at the moment.
- I would try to use some small fillets at the four screws in the housing for better reflection effect.
- The ground looks so constant grey. I would play a little bit with ground shape, color and lighting.
JBL no.1
I’m gonna kill you!!!
It’s not kitchen (dosh hi-rez). Gap - mmmm maybe I should use smth like direct computation for better look, “sharper”… Or maybe not…
BTW - it’s a material test! Fillets - screws are not final, thus there’s no fillets rightnow.
