Hi, I’m playing with the new Jet Engine template but I need to have the object horizontal. Everytimes I test it, the direction of the fire is from top to bottom. Any chance to change it ?
Many thanks
JM
Many thanks
JM
Hey,
By default the jet engine preset will emit from the Normal Z direction of the object, if you just rotate your emitter object 90 degrees it should work correctly.
If you don’t want to change the rotation of the object but still emit horizontally - you will need to adjust the discharge modifier for in the Fire Source. You can see how this works in the video here - https://youtu.be/7tkC71E4kmA?t=2311
Hi Georgi,
you know what ? It works ![]()
Thank you so much for your good work and fast reply.
You rocks
Cheers
JM
