I’m trying to achieve this look for already 30 days using demo’s of different render engines without success. At the end i came back to vray.
We need to purchase a new render engine as we need to render over 1000 rings and we can not afford to pay someone else do it, as they charge per image ofcourse.
So we have to do it ourselfs. We tried maxwell, keyshot and now trying vray.
This is what i achieve with vray. As you see it’s totally flat and dull. It does not have that “awesome feeling on the surface of the ring” that brushed and charming feeling.
I do now that there is some post work involved, but i’m pretty sure we can get 80% close with vray alone.
My attempt:
I used textures in reflect,bump en little bit in diffuse, tried different combinations, tilings, i also used mix =noise + brushed texture to get closer to the images we want to get.
If anyone can help us setup that material or scene to achieve that look we will get vray instantly. For us speed does not matter. We are after quality so we don’t mind waiting for long renders.
You’re not far off I reckon, some depth of field and more contrast should do it - if you’re using photoshop try using the unsharp mask filter but push the radius really far - it does a pseudo contrast effect and can give a nice tough grade to things. You’ll need to add some glossiness and the anisotropic settings for the material to get rid of any of those harsh edges on the brushes part of the ring.
I go and try right away. One more question before i go, is it right to put textures in reflect maps? Most materials i downlaoded to learn are always in bump..but it does not give me results i want. Sometimes i feel like two brushes where used in those images? one bigger one smaller? like a blend material? This does not seem hard , but it is hard to get that commercial look . I go try everything u advised!
To be honest most people will put textures in the reflection slot when they want the object to look dirty so if you had an object with big grooves cut into it, dirt might collect in there so you’d use a map to make it less reflective in these areas. For what you’re doing I don’t think you need it.
Omg I just read that cgpersia is a bad stolen site, my ex boyfriend told me about it, no wonder i can’t find it ! Typed brushed in search nothing came.
Also everytime i save, project and open my vray settings are always reset, i have to go and put those back again. Is it because it’s a demo ? I’m also using demo max.
I have rhino 5 from my work, but i heared vray for max was better so was trying the demo. I heared vray for rhino is badder then for max?
Budget is arround 5-6K. I’m also thinking to buy hdri light studio. (for those highlights)
I’m now on cgtextures but i can’t find brushes in high quality.
Keep in mind i still have to buy a cheap version of max to run vray unless vray for rhino can do this things too.
Brushes u can make urself… U know Photoshop>Create noise map>Motion blur in 1 direction>Done. Or use noise as source. Play with it, make different options details etc etc…
Thanks for advise Dadal. My fiancee has also made courses in the past for marketing and selling and it also ended up in those type of sites. Stolen bad sites. i guess it’s good for people from 3rd world countries to get access to software to learn but it’s painfull when u are the product owner believe me.
about the brushes! I will try to create 8k brushes.
Oke So i followed the advises but i’m still not where i need to be.
Now photoshop involved.
I forgot to mention, the reason i’m doing with max vray and not the rhino is also because of the hdri light studio. I tried the demo with keyshot maxwell and now vray max and it seems awesome. Not sure if it’s needed.
Should i post in the job section to see if somebody can create the look we are looking for? Am i allowed to do that? And how much will cost something like that?
So all i want it to put my rings tweak little bit and get that detailed glossy awesome ring metal u see in the pictures.
I’ve only dropped in simple ring shapes and some glass/diamond primitives.
The new BDPT would be great for this type of job, but I used Maxwell (as I’ve been using it a bit recently) as I wanted to see if there would be any caustics from the metals.
Let me know if this is similar to what you’re after and if I can be of any help on the project.
Sherridge101, thanks for your reply. I’m still trying 10 hours a day to get it right as our catalog is not ready. Ma favour goes to vray as i couldn’t achieve similar results in maxwell and a brushed simpe metal took like 30 min to render. I did even took the vtc course to understand maxwell and their materials.
I have not enough rights to access the picture you posted. I would love to see what it is so i can tell you if it’s what we are after.
Those are all real pictures but we can not afford to do this with a photograaf, plus for new designs we have to always make the ring. (we are an upstart) So we need to achieve in 3d and go knock on doors of juwery stores to put our collection in their stores. So the renders are most important.
Can u post it on a extern image sharing so i can see it? Thanks!
I read alot that maxwell is esy, point and shoot but with vray steep learning curve, but i don’t know why i tend to understand what i’m doing in vray. I took lynda course and some tuts. I feel i have more control over it.
I have some problems when exporting from rhino to 3ds. I get that vertical lines on the ring which messup texture. don’t know how to fix it. I will post it in rhino forums soon about it.
Need to work on the texture to strech less. But still it needs some work cauz now it looks too much of a metal then jewelry.
