For better details I would use the QMC-LC combination. I suppose so you have used the IM instead the QMC.
Anisotropic reflection: anisotropic effects are caused by little scratches like stripes. If I had a problem with the effect, than I would use a stripe texture as test texture and see, are the stripes in the correct direction without break everywhere. If you have breaks or the uv direction is changing, than you should repair it befor.
I know Vlado settings and what you use…but I decided to used
a IM 1.0 and a secondary QMC 0.7
It’s much faster…
If you have some QMC LC settings instead of a IM QMC that are just as fast and does a nicer job, just tell me !
IM QMC does great but sooooooooo long.
Jp
wow whichever hard render of the dining room has much geometria I like the handling of the light in those interiors this obtained with the lights of vray or you used IES if you used IES you can say to me as use to them because not them encounter in v-ray for rhino
oh and another thing you place some iluminacion outer aside from the GI for those interiors because I usually have left to something dark nonprofit that the light between a the building of that way, since it beams
