just palying with ps....su+vray+cs2
still need to learn ps.. c&c are most welcome
Re: just palying with ps…su+vray+cs2
Jeff
I suggest more transparency for the water to avoid that ‘chrome’ look. Also have you tried Marc’s procedural water material
material > bumpmap > noise > Perlin noise option
(play with the settings and you will get all kinds of water…)
I like the blurred foreground fern - is this your trademark?
Regards
David
thanks david i will take a look at that..
the fern? maybe i got less ps landscape material and this fern is 1 of my high quality image thats why i used it always…
here are some water using only ps.. incase of rush renders…
david i still havent tried the bump water maybe after this project bec. i dont have time to render again… ill study it and post 1 render using that technique soon
and another view (raw render no ps)
regards jds
can you share me your setting (option in vray}? i need it
thanks very much…
can you plees make a tutorial how to get the disp. wright on the rooftiles..
Regards,
www.dwanimations.112desgin.org
sorry but the roof is not a displacement its a model and it really needs lot of patience doing it…
thanks and regards jds
