Keep HideUnusedNodeslots in SME "on" by default
Hi!
Is it possible to change somewhere settings of SME in a way it keeps HideUnusedNodeslots (H) option active by default for all new opened materials?
I tried to change this parameter in SME.ini file from HideUnusedNodeslots=0 to HideUnusedNodeslots=1, but it didn’t change anything.
I make it active for all maps/materials I work with in order not to blow up space used by materials on SME field, so it would be nice if this option will be active by default.
I’m with you on that. unnecessary clutter. l’ve never found a solution though.
Yes, I agree as well. Maybe worth posting on Autodesk forums instead ?
I’ve done it an hour ago :smiley:
Great, thanks !
I was about to do so if needed. I think they can easily add this to the Slate’s preferences …
