When working with Vantage one very powerful tool is that when you save cameras , Vantage keeps the proportion of the frame for each camera.
This way you navigate around your scene like a cinematographer , you find the best place for the camera , the lens field and framing and you this makes Vantage the best and most intuitive composition rendering software.
Unfortunately when you want to high quality render these cameras, you need to manually retype the proportions, which is very counter productive, specially when you queu render.
Can you make it so that high qulaity render and render queu starts with the same aspect ratio (proportion of frame) as the camera you have setup, with the possibility to increase it proportionaly or not (like in camera settings of Vantage)
