Keep scene in cache for DR nodes
When rendering multiple camera angles of the same scene with Distributed Rendering, V-Ray re-transfers the entire scene to DR nodes for each frame — even when only the camera and resolution have changed. For large scenes, this re-transfer adds significant time before nodes can begin rendering, and in some cases the render session risks timing out before nodes even contribute.
Proposed improvement: Cache the scene data on DR nodes between frames so that when only lightweight changes are made (camera transform, resolution, render region, etc.), V-Ray sends only the delta rather than the full scene. This would allow DR nodes to begin rendering almost immediately alongside the local machine on subsequent angles, rather than waiting through a full scene transfer each time.
This would be especially impactful for architectural visualization workflows where it’s common to render dozens of angles of the same unchanged scene at varying resolutions.
Have you tried exporting the animation to a .vrscene and then using V-Ray Standalone to set up the DR? This method should export the whole animation at once.
