Kerosene Lamp
im kinda experimenting different light effects, light materials and so on on and so forth.
im still not satisfied with this output but at i think the light material is almot there. i still need to rework the glass, and the decay of light too.
here is the Raw render image.
here is the screen grab.
and this is the post proccess, which is close to the output that i want to achieve.
Re: Kerosene Lamp
hi there, there is no refraction on that glass, add some and it will be better, and the displacement is too mutch strong.
Re: Kerosene Lamp
there is refraction but then i made a mistake by moving the transparency too far because of trying to control the omni light passing through the material. so the refraction was jumbled. thanks ande.
Re: Kerosene Lamp
nice one sir nomer…
i like the way you do the flame…
but the glass seems done in post processing :frowning:
Re: Kerosene Lamp
right ka louie… actually i struggled in tweaking the glass material on this thing, without seing much of the reflection. i guess one of the failed test that i ve learned so much.
Re: Kerosene Lamp
nice one. nomer. my only comment is the glass somehow got lost. maybe HDRI reflection is needed. :wink:
Re: Kerosene Lamp
art, i actually use hdri, but the problem was i overworked it in post processing. ok i will update this one, as i knew what had happen and will do it without even post processing it.
