An option with lights during animation or between senses..
Key on or off..
Example, creating day and night time need to switch off with camera K as key-frame set
Key on or off..
Workaround: setup you scene with lights at night time (set global brightness at a high value, so that you need low light intensities). Now change to daytime and enable automatic brightness. Your lights should be to low to visible now. ![]()
Thanks for your inquiry.
As mentioned in the other thread you’ve posted, I’ve happily added your feedback to the existing topic!
A neat little work around that I’ve been doing, as far as post production wise, is creating two sets of lights. One set with a light source and illuminated center; One set with no light source and no illumination.
Create and render a scene with light set 1.
Render same scene with light set 2.
Overlap the scenes and dissolve the two scenes into each other and you get a nice little dimming effect.
Again, that would be for like a video product instead of real time product.
What is stopping you putting the light sets into a layer within the model and turning them on/off by turning that layer on/off?
You could also just zoom the ‘artificial light brightness’ setting up/down from the Enscape settings tab.
… Personally I would like to make a light switch within the model a ‘hotspot’ that could be clicked on to toggle specific lights on/off (Or technically define the visibility of each of the current layer set - just put the lights on a specific layer)
:thumbup:
+1 here
Added.
Perhaps the solution provided by @Gadget_1 just above may also be helpful in the meantime.
not in movei , not in panorama , not in EXE , the @Gadget_1 method is good only for Sketchup viewport
