Hello , how can i find keyboard command for " Show Corona VFB" in customize user interface ?
Hi
You can find the script written by DeadClown here
https://forum.corona-renderer.com/ Show VFB: need help for Macroscript
Edit
Actually there is already command Show Corona VFB which comes automatically with Corona, so you don’t need that DeadClown’s script at the moment. You can find Show Corona VFB command under Corona renderer category in Customize User Interface dialog, and you can assign your own hotkey for this command.
Thanks for reply , just one moment , in my configure user interface does not appears “Show Corona VFB” . Corona section contains only several corona command
Hm..
So maybe you should try DeadClown’s script in this case. I’ve installed it few years ago, didn’t change anything and it works well for me
This option is present in the Corona v6 daily builds. And will be present in v6 when it is released.
Thanks,
Rowan
Thanks ,Does it means i can’t assign keyboard command for Corona Show VFB ?
