Kiev appartament
Kiev appartament, corona render.
Very beautiful! (Очень круто :wink: )
Did you used albedo parameter in your scene ?
Thx)
Yeap. and there is one trick
in all my works I switch to the 1.4-1.6 gamma in corona dev/debug settings
And it is enough of exposure in gamma 1.4-1.6 ? Seems you make hard post production after?
it is raw renders
there is no post-production
in these scene i set extremly hight exposere and highlight compression
something about 6 and 24
Well, As I told the renders are really nice. I think that you should tweak some post processing settings and light parameters to find balance for preserving nice hotspots. IMHO it will be even more realistic then now
tri-artem: That’s an interesting approach you got there.
I like the fact that you can tweak setting within Corona to achieve a more artistic effect out of the box. A downside for this approach is that it’s hard to use some postwork since there’s already such a high contrast in your scenes. A saver way would be to render out a fairly balanced image and tweak it to your likings afterwards. But then again…it’s a nice workflow you got there.
Wow what where the render times to get this so clean?
something about 3-4 hours on i7 2600
I’m an interior designer
and for me its work good
I see how my design feels like without post production
Nice Rednerings! This workflow seems to have overally better highlights cover, there are many workflows, this is good approach.
Great renders and very interesting rendering setup, I’m going to have to do some testing…
Very very nice results. I love the natural/realistic looking lightning and the overall mood of the images. I’m curious what kind of albedo values did you use…how low and how high did you go?
Thanks! Nick
Fantastic renders especially the natural looking lighting. Can I ask where you got the lounge chair model from and your material set up for the wooden flooring… Many thanks
So God damn good!
