Kitchen renovation
Dear all…
I’m facing difficulties on how to achieve lighting on interior scene rendering.I’d followed step by step from the manual but at the end,once render the rectangular nor omni lights of vray become dark or doesn’t appear to be light source.Could somebody give link to tutorials related to this?really appreciate if anybody could hepl me on these.By the way,i’ve tried few times on the rectangular lights and also the emissive effects on objects,but it doesn’t come out as what i’d expected.i dont know whether my visopt setting or else would be the problem..
Re: Kitchen renovation
hi, mohd. i use to have the same problem, in my case it was that the the number in multiplier was too low, so i need to put it maybe on 10000, think you need to play whit the multiplier on the intensity of the light, other thing that can help your render is the engine your using, try irradiance map primary and light cache secondary on the options. also gi ilumination multiplier and the other thing that can help is to change the parameters in camara settings in the options, specifically film speed iso, shutter speed and f number, check it out, maybe this can help, other guys in the forum told me this advices and help me so much.
thanks teofas…i will do that.wait for the results soon.Thanks again.
the lighting is still dull. maybe you wan to play with vray camera.
sorry nomer…i’m quite new to this..what do u mean by that?vray camera?
you can look for it in the option settings,then modify the film speed (ISO) to maybe 160 and modify your shutter speed down to 40 all of this is in the camara, in options, if this settings dosent work for you play around with them until works for you, a good advice i also recived is to read from beggining to end the manual…ill wait for the changes in your render. :wink:
i dont know whether this is ok or not..still improving.I’m impressed with some of u guys especially newbies,u guys manage to get good rendering even u r just a first timer.Just wanna know how to achieve the emissive effects on the objects.I’d tried few times but once i render it doesnt glow.Could somebody give some tips..c&c are most welcome.By the way i’m attaching another view at the dining.As u seen the lamp on the table doesnt glow.I want to show that the lamp is on.Sorry for my bad english.
