Kitchen visualization. Feedback appreciated. <3
I am pretty new to this, so feedback in general and recommendations to do better are highly appreciated. :wink:
e.g. still don’t know how to integrate a nice outside view like in the window on the right side without compromizing my outside lighting.
Cheers to all of you! Have a nice weekend. :stuck_out_tongue:
Hi Andreas. I expect you will get some good feedback here. what software are you using? Max 2021/Vray 5 or… Are the second two images of a collection of models you purchased or did you create those objects? the window to the right is so small that I don’t think you would see anything out of it anyway. BUT it could be nice to show some sunlight shining thru it. Easiest is probably to use a vray sun/sky for that. In Max - enable use scene lighting and shadows for your camera shaded viewport and you can interactively aim the sun light into you scene to make it the way you like.
If you want to show something outside the window, make your window glass transparent and you can save the render with an alpha channel and then add an image that is seen thru the window in photoshop. Or map an image to a plane and move it around so it shows what you want thru the window. Then use object properties and vray properties to disable shadows, gi etc. Put the map in a vray light material and assign that to the plane. That will allow you to adjust it’s brightness independent of the rest of the scene lighting.
I think the rendering would benefit from the interior being much brighter It kind of looks like night inside and day outside? Use vray overide material to make everything gray and leave the window glass transparent. Render first with only sun shining in. Adjust camera exposure to suit. Then if needed add maybe a plane light up in the ceiling with color temp @3K. In vray properties make plane light invisible and uncheck affect specular and reflect. Adjust intensity to suite. Then work on lights illuminating shelves.
Maybe move the camera to the left to get some more perspective versus straight on look? Hope this is helpful to you.
You put a lot of work into it; good job. I think with some fine-tuning, it could be a nice image. I think working on a key light might help and fill it with fill lights. My eye is going all over the place, and you control that with light a lot of the time. Our eye goes to the highest contrast part of the image, and in your image, my eyes are bouncing around like a ping pong ball. Actually, the first thing I see is the stove, which seems to be a photo pasted onto a box. Dial into things and you’ll have a nice image.
I look forward to seeing iterations.
