Hello!
My first kitchen. C&C are wellcome.
Altabas
Hello!
Altabas
Gorgeous!!! :shock: :shock:
Please explain something about lightning!
thanks and congrats
Neo
Very nice texturing, but the table is ca 20cm higher than normal. Chairs too. There is difference between warm yellowish light inside and the white background lighting.
i dont like the target
but I really like the metal materiales that u used…tell us something
about them.. ![]()
nice render!
This is a great scene!!! i like everything 'cept the lightning because i have the impression on the light inside that its morning and from the light outside i think its mid day!
Other than that, looks awsome
hi to all and thanks for your quick reply!
You asked me for the lighting. I used two vraylights, one in the windows and the other at the left side only to give me a bit more of light inside. Also used a direct light as you can see. The window vraylight was skylight portal and stored with the irradiance map. The direct light with area shadows.
Say about the direct light that looks more as the sunset lighting but in real the light takes that colour because of the floor. In fact the light is practically white with only a very slight touch of yellow.
maybe you will try to uncheck store with irr map. this way you will get more detail shadow. it will increase render time, but try it. ![]()
