Hey every one, hoping that one of the computer guru’s here can help me.
Im faced with the delemma:
I got two boxes, and I need to use KVM switch to switch between them. However, the problem is, that one of the boxes does not has PS2 connector for the mouse. So, I need a KVM usb switch? I looked some up, it seems all of them eather have only usb ports and no PS2 ports, or have just the ps2 ports and no usb ports. I kind of need both, since my keyboard is ps2.
Or should I just get a usb switch, and a ps2 to usb adaptor?
Thanks!
@Morbid Angel
Belkin has some products that with both PS2 and usb connectors.
http://catalog.belkin.com/IWCatProductPage.process?Product\_Id=298802
http://catalog.belkin.com/IWCatProductPage.process?Product\_Id=379522
I use the last one but I am not too satisfied with the video signal because it has tiny tiny flickering, so I don´t use it for my workstations. But it´s great for my render nodes.
Preisler
Both are “workmachines”?
if not, a simple software solution, like VPN, does the job (really usefull if, like me, some of your machines are 5 floors below)
VPN, or just RDP (Remote Desktop).
I use RDP alot to check things on renderslaves or to convert a CAD drawing for 3dsMax
thanks guys, I sorted it out. I just got an all usb kvm, and a ps2 to usb converter for my keyboard. Worked fine ![]()
Exept the kvm is picky where you plugin the mouse and keyboard, i.e. I plugged them into opposite slots first and it didnt work.
I use a belkin flip usb kvm and it will only work correctly if I boot up ‘machine 1’ and immediatley turn the switch over to ‘machine 2’ as ‘machine 1’ boots, once it has booted up I then flip it back to machine 1 and then login to windows, similarily if I need to boot machine 2 up I have to make sure that the kvm is set to machine 1, I also avoid moving said mouse during bootups, weird yes, took me a few hours and a load of failed boot ups to arrive at this outcome.
