laboratorium animation
Hi!
I need to do an animation of some kind of cartoon labo with all kinds of pipes and bulbs with liquids an gasses.
For example a bulb filled with some liquid should ba animated so that the liquid seems to run down a pipe and fill up another bulb. This shouldn’t be realistic, but I even don’t know how to do it unrealistic. Should I work with animated booleans (a pipe inside a pipe which is the liquid)?
Any hints, tips or clues would be very appreciated!
The only thing I can animate now is simply moving stuff and adding some modifiers. I never did something like this.
I don’t want to use fluid simulators.
Gas shouldn’t really look like gass, in fact there should be no difference between liquids and gasses.
Thanks for any help!
wouter
oki flipside I like figuring out this kind of tricks so created this scene for you (15 minutes :)). Hope you will understand how it works.
http://lukx.hellnet.pl/misc/vray/flipPipes.rar
I really appreciate your help lukx! But there’s a small problem… I can’t open your file as I’m still on max5.1… Sorry!
Will try to download max7 demo, but I already did that a while back so I’m not sure if I can do it again.
oh! I did it with max7.5. I’m not sure if in max 5.1 are modyfiers I used (Shell, Path Deform Binding (WSM). Anywya I will try explain what I did.
I created pipe (spline with renderable option thicknes 5) then edid poly removed top and bottom cover. Next putted shell modifier to get glass thicknes. Next I copy spline I used for pipe and created circle spline a bit smaller than pipe radius. Next I put extrude modifier on circle and path deform binding modifier (then played with it a bit to get same shape as pipe. This is my fluid. Now with animatingt extrude you will make fluid go down or up inside the pipe.That’s it.
