Lag!? ( due to material or material editor )
I’m testing vray 2.0 to see if our workplace should upgrade and found that when the material editor was open, there would be times of lag, especially when coming back from a render.
questions is, anyone else finding lag issues cause by materials or material editor?
For now its back to 1.5, more stable it seems.
Thanks guys
In another file I’m getting this. // EDIT < Nevermind, this is irrelevant. Because of the problem below, I forgot I had enabled “update active material only”
See attachment.
There are no changes in this regard for V-Ray 2.0; I have not seen similar issues. When you say there is a lag, what exactly happens?
