Hi All,
I have started encountering this issue, where Vray causes a lag when i open “Render Setup” or the “material editor”. Any parameter i change causes Max to freeze for for a good 15-30 seconds. All my material previews have gone black. Surprising that this issue didn’t exist before and started in the past 2 weeks.
Tried the following solutions but had no luck,
- I tried switching off the render material option. The material editor issue was fixed but with no material previews :(. The problem with the render setup still stays the same.
- I initially thought it was 3Ds Max issue, but tried uninstalling Vray and it fixed the issue. But no Vray :(. This made me conclude that this is caused due to vray not max.
I am running 3ds Max 2021 and Vray 5 Hotfix 2.
i7 9th Gen,
Nvidia 2070 RTX
32Gb Ram
Any help or suggestions will be great as this has caused tremendous delays in my work speed.
