Lands design bug
Please read here:
http://rhinolands.com/forum/topics/lands-design-open-for-render-engines-like-vray-for-rhino?commentId=6420662%3AComment%3A36029&xg\_source=msg\_com\_forum
Just downloaded the plugin and tested it. The issue will not be reproducible in the next V-Ray version.
For now, the workaround would be to manually edit the file path of the diffuse texture (use vrayMtlFromRhino command, then the V-Ray Material editor).
Kind regards,
Peter
Thank you, I forward your answer to Albert from Asuni.
Update: the workaround from my previous post may not be sufficient. It could also require disabling materials’ Opacity map checkbox and enabling “Diffuse Texture Alpha”.
If anyone is finding it impossible to overcome the current issue, simply send me a PM.
Kind regards,
Peter
