I’m stuck on this task. Besides distant full room views, I need to render close-ups as on the picture above. I tried everything - Max Hair, Corona displacement, Corona Scatter. None of these give at least good results.
Curious as to why you’d need to render closeups of carpet unless the CGI’s are for the carpet manufacturer themselves, and if that is who the CGI’s are for, then why not ask them to send you large samples so you can photograph and create your own displacement maps?
It’s related to carpet cleaner product. I need to show cleaner machine directly on carpet. There will be close-ups to machine parts and carpet will be part of the pictures.
Thank you so much! I knew about Picksells rug and seems like this is exactly what I need. Just purchased model and I’m really curious about the results.
Try using Corona Scatter. Create few boxes chamfer edges a bit and add a turbo smooth, perphaps some noise. Use variations in scale and Z axis mostly, as well as some rotations. Might actually do the trick.
Thank you all for the tips and guides. Here is a previews of latest revisions. It’s pure Corona Displacement. Shoes are placeholders. I guess I’ll need to make carpet more fluffy and soft, but I think I’m on the right track. What’s your opinions, guys?
thank you for the comments and feedback. I used pre-made Carpet Low Beige material from Corona Material Library. Just replaced displacement map with custom one - see attachment. It’s rough and not seamless (but you get the idea), I will post final version asap. If you zoom in, you’ll notice soft noise on light parts of the texture - this is to give soft fuzziness. I also altered displacement and SSS values to gain required look. Displacement Screen Size is 0,6 px.
By the way, where did you got the carpet preset ? I’m trying to install it from the library but there’s only the legacy materials. (already tried from the Corona7 RC4 dropbox)
