Large-scale project problem
Hello I recently had a problem. When I’m interested in rendering in revit on a large-scale project.
The look on the camera is cut off and the good result cannot be obtained. What is the solution to this situation?
Can you maybe take a screenshot and opload. maybe then I can help :slight_smile:
This sounds surprising, but maybe… the maximum view distance in Enscape (by default) is set to 14 km. Is it possible your project is larger than that, and you still want to see it’s entirety?
If not, as Maarsso said, it would be great to have a screenshot.
