Last bucket bug is back
last bucket are stuck on IRmap calculation.
10mn for most of the map and the three last are now running for about 30mn still not ended.
3dsmax 2015 SP1 / Vray 3.00.07
SOLVED
Merged into a new file, and now it’s OK
I’m glad that it’s solved now but if you still have the original file, please send it to me at vlado@chaosgroup.com so that I can find and fix the problem.
It does seem to be a problem here too. I’m rendering with some draft settings and GI turned off; the bulk of the image renders in about 10 seconds, yet it will take over a minute for the last bucket or two to finish.
Im also now getting this issue - stuck on last bucket of IR map.
Do you want me to send the scene?
Yes, please send it to support@chaosgroup.com
FTP could be provided if needed, just let us know on the same email address.
Let us know what is the exact Vray/Max version that you are using.
Emailed a dropbox link
Thank you very much for the scene.
We would like to inform you that we managed to render with without any issues on a single machine with version 3.00.07
Please update to the latest official 3.00.07 version and run the same test in your environment.
