last bucket taking forever?
I really need a scene where I can reproduce this; also some more information about the machines you are using (# of cores) will also be useful.
I found the problem. The frame range was originally set to -300 to 900. The renders for frames -300 to -1 were all messed up (bad IRAD flicker, lots of objects not illuminated correctly, etc), so we renamed the IRAD frames to fit a 0 to 1200 time range, went through every scene and moved all animation keys +300, re-rendered the first 300 IRAD frames, then re-rendered all of the final frames 0-1200. The final re-render worked well on the first 300 frames where we had fresh IRAD data, but when it hit the IRAD frames that had been renamed, machines started hanging on the last bucket.
We tried to save some time by not re-rendering all of the IRAD frames, and it came back and bit us in the butt. If you still want more info about what my setup is, or my scene let me know. Doing it the “right way” did not have the last bucket problem. I can’t remember the last time we tried to render negative frames, but from this experience we will avoid it in the future.
-Ray
I will happily send you a super-simple scene that causes this problem here. To test the system on our new dual quad-core, I created a scene with a few random objects. Didn’t apply any materials, just default colors. Added a VRay plane light. Probably less than 400 polys.
I get the last-bucket hang. I think the scene should render in less than 5 seconds (without this problem). It is a truly tiny scene.
Windows XP Pro x64
2x Xeon E5504 2.0GHz (Nehalem, dual quad-core)
12GB RAM
3ds max 2009
VRay 1.5 SP3a
I also have a somewhat larger scene (only 6,000 polys, though) that demonstrates slowness problems. Nothing special about the scene at all. No grass or displacement, just basic lighting and texture maps. If memory serves, it uses only 2.2MB of RAM. *** It uses only one core on the prepass stages.***
I saw some other threads that mentioned a couple possible fixes. They were:
renderers.current.system_numThreads=0 (it was 0)
I also changed the number of Light Cache passes to 16 (was 8)
No difference.
Where do I send the tiny test file that produces the last-bucket hang?
Thanks!
You can send the scene to me at vlado@chaosgroup.com; we do have a dual quad-core machine here, but so far I have not noticed any issues with it.
Same problem here.
I don’t have time to make some in depth test, but sometimes, last buckets, very simple shader, simple model, take very long time to render.
See this. It’s just a simple car-paint shader. But the same happen with all shader.
I render this scene in DR and the last bucket take too much time. 3 minutes is very high rendertime for this 32 size bucket with i7 970 # 4.2 Ghz with 24 GB RAM with LWF + Universal setting noise thres= 0.01.
I see also in some other scenes the same behavior. I remember a scene that the last bucket take 20 minutes! I don’t remember if that happen only in DR mode or also in local mode. Sorry.
I want just report that.
Bye
We are having this same issue here, whichever the last 3 or 4 buckets are, in any part of the scene the render will sit there for half of the time it took to render the rest of the image. Has anyone found a solution? is it omething to do with the raycast settings? we turned off render channels and the trees too!
Used to have this problem in 1.5 running 8GB of ram. Key thing that I’ve started doing since then is using the QMC for primary GI calcs and upgraded to a 980X + 24GB of ram. Haven’t had this problem since even with a few similar spec’d rendernodes in DR. It’s definitely a bug though, most likely to do with render sampling settings and or DR.
we’ve been having this too, across all machines dual/quad and up to 16 gig ram, didn’t seam to matter
I was thinking it was a sampling issues when a bucket got to a hot reflection. Looking forward to any fixes on this
Same here… It started fine rendering swiftly at about 1.5 min per frame. I was all happy.
After about the 20th frame it went to 3-4 min per frame because of that blasted last bucket…just sitting there all retarded.
Hipnotized, I sat there looking at it, frame after frame. I don’t know why I stared, and it strikes me how much time I lost just glaring at that bucket, dumbfounded and increasingly irritated. Looking back, I realize my angry gaze just added to the problem. I could of just walked away:+)
Same here on a very simple scene.
i7 970 24Gb
i7 920 12Gb
Max 2011 + SP1, no more.
_Export_Camera_Vray3.zip (71.8 KB)
Anyone ? any clue ?
Best regards
I had that problem on a large scene last week. Aerial animation with lots of trees - rendering ground to a halt after about 120 frames. Render time went from 2-3 minutes to 10+ hours. Hanging on the last buckets - not just the last bucket, the last bucket(s) plural. Thought it might be a bug with Forest Pro, but after a day of troubleshooting the scene, I found that upping the dynamic memory from 2000 to 4000 fixed it. Definitely a bug in how it is handling the memory. What use to crash max now seems to make buckets hang.
Ryan
I have had the stuck last bucket issue in several different cases. Scenes with no plugin used anywhere, ranging from very complex to super simple and also in some exterior scenes where I used Forest Pro to distribute thousands and thousands of trees / grass objects. I have my Dyn.Memory limit set to 10000MB (12GB physical memory). Most of the scenes that displayed this problem didn’t even come close to using 10000MB, more like 3GB to 4GB tops. I have also tried setting it lower and higher with the same results. So it’s not just memory handling causing this issue, or maybe it isn’t even a memory issue at all? And even better, the same scenes that had the issue rendered just fine when I had to do them again… so where’s the logic in that? :stuck_out_tongue: it’s a weird, seemingly random, problem… and it’s also hard to test settings because of the randomness in which this occurs.
The only thing that is common in all my tests is that I use DR. So maybe it is some kind of network communication problem??
Hello vlado
We recently start using vrayStereoscopic cam.
Some scene with vreayStereo helper taking forever at last bucket.
When recreate the helper the scene works normally. And with time, last bucket taking forever.
64Bits : Vray 2.0 SP1 - MAX 2011 - Seven SP1.
Another strange thing with vrayStereoscopic helper, it need to be visible to work…
Best regards.
Can you send me one of these scenes to vlado@chaosgroup.com for investigation? I would also like to ask you get me a process dump for the 3ds Max process, but I will explain this in the email.
Is there any word on this issue? I’m seeing it too.
we’ve been using it for sometime now and is fine for us, I have had problems with last bucket stuck on non stereo shots.
We only got one scene for this and I’m not sure it’s related to the same issue; if you can get us any way to reproduce it, it will be very helpful.
Same problem. ALso saw .1#IND and max tree depth 1
Which problem? Can you get me a scene for this?
