latest 1.5 work
here is my latest work using 1.5. I am loving the sun/sky… Comments and suggestions wanted.
Excellent. Looks really good.
Two things though: Your bright areas seem a bit burned out. Maybe add some Reinhard burn? Also, the carpaint looks wrong and distracts from your image. I’m not sure the problem exactly, but maybe your base coat needs to have (more) falloff, or more glossy reflection.
How did you do the box hedges in front? Is that the PArray hedge method?
Great work Bobby! :slight_smile:
Replies
thanks for the replies… I used photoShops Diffuse Glow, which is probably causing the bright being to bright. I agree with the car… thanks. The bush is from Evermotion.. great models! We buy them everytime they come out with a new one becasue if we just use one model it pays for itself.
Update
Here is the rear of the same building
