latest phoenix for vray 3 failed to initialize with backburner
Hi there,
stucked with that one, as the title says,
i upgraded today the latest phoenix version from yesterday,
now when i want to start a renderjob via backburner, on the rendernodes max won`t start because of failed to initialize phoenixfd.dlr?
Never had a problem with that.
Simple teapot testscene same result, when i uninstall phoenix on the rendernodes it`s working again,
donwloaded the nightly from today, no change… any suggestion on that one?
Thanks i advance!
Oh, if it says it failed to initialize phoenix.dlr, this is a very strong sign that Phoenix and V-Ray are mismatched on the machines. Which Phoenix and V-Ray versions do you use? Could it be that you are installing Phoenix for vray3 + V-Ray Next Beta or Phoenix for vray4 + V-Ray 3.6?
We are experiencing the same problem submitting Phoenix 3.10 jobs to Deadline. We are using V-Ray 3.6 for Max 2016.
Rendering works fine locally and when rendering via Deadline on workstations.
Thanks guys, we’re trying to reproduce it here as well…
Hey,
Seems to be working on our side.
Can you send us the exact error messages and the installer names for Phoenix and V-Ray that you are using?
Thanks,
These are the installers:
phoenixFD_adv_31000_max2016_vray_30_x64.exe
vray_adv_36004_max2016_x64.exe
Below an excerpt from the error log:
2018/02/16 15:40:37 ERR: [04692] [12552] DLL <C:\Program Files\Autodesk\3ds Max 2016\plugins\vrayplugins\phoenixfd.dlr> failed to initialize. Error code 126 - The specified module could not be found.
2018/02/16 15:40:50 DBG: [04692] [12552] Starting network
2018/02/16 15:40:59 INF: [04692] [12552] [V-Ray] V-Ray DLL version is 3.60.04
2018/02/16 15:40:59 WRN: [04692] [12552] Missing dll: phoenixfd.dlr - PhoenixFDOceanTex
2018/02/16 15:40:59 WRN: [04692] [12552] Missing dll: phoenixfd.dlr - PhoenixFDFoamTex
2018/02/16 15:40:59 WRN: [04692] [12552] Missing dll: phoenixfd.dlr - LiquidSim
2018/02/16 15:40:59 WRN: [04692] [12552] Missing dll: phoenixfd.dlr - PHXFoam
2018/02/16 15:40:59 WRN: [04692] [12552] Missing dll: phoenixfd.dlr - PhoenixFD Atmosphere
Very weird. If you log into a sim node, can you start 3ds Max and create a Phoenix simulator without problems?
Sadly no, I get the popup with “failed to initialize phoenixfd.dlr” error message when starting the 3ds Max application.
Sounds like a bad installation then. If this does not happen on a workstation and only on the node, you have to look for the differences between the files in the …\3ds Max 2016\plugins directory.
One other thing that comes to mind is to run both the Phoenix and the V-Ray installations explicitly as Administrator. If this does not help, would it be possible to zip and send me over the phoenixfd.dlr from 3ds Max 2016\plugins\vrayplugins? Also, except for V-Ray and Phoenix, which other plugins do you have installed? It might be caused by a third plugin, though we didn’t have such issues before.
Cheers!
Hm seems like i`m not the only one having issues,
i was aware to check if it`s for same version,
double triple checked and installed it (as admin etc. ) cause installing updates many times before for years…therefore also checked if there’s a new license server available :wink:
For me what is working right now, i grabbed an older nightly (guess i was 15.jan release) which is working in the means that backburner is starting at least.
So at least i can render jobs (scenes without phoenix) on my farm. Try that if it prevents you from rendering on the farm.
Can`t say something 'bout phoenix behavior with the old nightly though, not working on a phoenix scene right now.
Thank you for the suggestions Svetlin,
Tried reinstalling with administrator rights, sadly no difference. The .dlr file is identical in size on both workstation and sim nodes. Also, we have several sim nodes with the same install which would rule out a bad installation as it is the same error on all slaves. Have a test going right now and it renders perfectly on the workstations as slaves As you mention Svetlin, we haven’t had any problems with previous builds of phoenix with our third party plugins in the past, but I’ll look more into this over the weekend and post an update. I’ll try send you the .dlr file.
Thanks so far.
I know it is of no help but I use phoenix/backburner and it has workedfine on the latest release :S When I had that issue in the past it was indeed a bad install.
That’s extremely weird and what’s even nastier is that we can’t reproduce it here. If by Monday we still haven’t figured it out, is any one of you guys available for a remote session? I’d like to run the phoenix dlr through depends.exe and find out what the missing symbols are.
Either this, or comparing the entire setup of a working versus a non-working PC would answer this, but the latter would be more difficult. @olika , are you running 2016 as well?
Hi Svetlin,
yes I’m on Max 2016
Alright, the Jan 15 clue was a very helpful one! I prepared a 3.10 build for Max 2016 with a change that might be what you need - can you guys check if it fixes the issue?
https://drive.google.com/open?id=1jgSirX33fEcXEijucX5J\_IAtpWpTTycM
Alternatively, you could try installing the VC++ 2015 redistributable from Microsoft’s site: https://www.microsoft.com/en-us/download/details.aspx?id=48145
Please ping me if any of the two solutions does or does not work.
Thanks guys!
Hi @Svetlin.Nikolov ,
i can give positive feedback!
Downloaded and installed your build and backburner server is starting max normally on all rendernodes, great!
Did not tested a phoenix scene though, but i assume that was never the problem.
Thanks a ton! Yes, the issue was with the Phoenix plugin missing the vc++ runtime - you could install it manually or it might have been installed by another software, such as a newer version of 3ds Max, Maya, or another software. I guess this was the reason it worked on a workstation but didn’t on a slave - because whatever software brought the vc++ install, was on the workstation but was not needed on the slaves.
This affects Max 2016 and older. We are going to substitute the builds on the chaosgroup website with updated ones. The latest nightlies should also be working now.
Again - thank you very much!
Can also confirm this worked :slight_smile:
Thanks!
Woohoo! Thank you guys and sorry for the trouble!
Cheers!
Cool! You’re welcome, glad i could contribute a bit :roll_eyes:
