Latest Update not loading in SketchUp 2026
Extension Errors Report
SketchUp: 26.1.252
OS: Windows 11
Ruby: 3.2.2
Extension: V-Ray for SketchUp (7.30.00 Apr 06 2026)
Error: LoadError (cannot load such file -- C:/Program Files/Chaos/V-Ray/V-Ray for SketchUp/extension/integration/helpers/sun_helper)
C:/Program Files/Chaos/V-Ray/V-Ray for SketchUp/extension/integration/helpers/helpers.rbc:9:in `require_crypt’
C:/Program Files/Chaos/V-Ray/V-Ray for SketchUp/extension/integration/helpers/helpers.rbc:9:in `module:VRay
C:/Program Files/Chaos/V-Ray/V-Ray for SketchUp/extension/integration/integration.rbc:28:in `class_eval’
C:/Program Files/Chaos/V-Ray/V-Ray for SketchUp/extension/integration/integration.rbc:28:in `require_relative’
C:/Program Files/Chaos/V-Ray/V-Ray for SketchUp/extension/integration/integration.rbc:28:in `module:VRay
C:/Program Files/Chaos/V-Ray/V-Ray for SketchUp/extension/integration/integration.rbc:1:in `block in module:VRay
C:/Program Files/Chaos/V-Ray/V-Ray for SketchUp/extension/init.rb:17:in `class_eval’
C:/Program Files/Chaos/V-Ray/V-Ray for SketchUp/extension/init.rb:17:in `require_relative’
C:/Program Files/Chaos/V-Ray/V-Ray for SketchUp/extension/init.rb:17:in `block in module:VRay
C:/Program Files/Chaos/V-Ray/V-Ray for SketchUp/extension/agreements/agreements.rb:23:in `enforce’
C:/Program Files/Chaos/V-Ray/V-Ray for SketchUp/extension/init.rb:15:in `module:VRay
C:/Program Files/Chaos/V-Ray/V-Ray for SketchUp/extension/init.rb:4:in `<top (required)>’
C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/extensions.rb:197:in `require’
C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/extensions.rb:197:in `load’
C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/vfs.rb:18:in `register_extension’
C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/vfs.rb:18:in `module:VRay
C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/vfs.rb:5:in `<top (required)>’
Hi @ValeroStudio ,
I’m very sorry to hear that.
Do you see this error when SketchUp starts or when you try to activate V-Ray for the first time?
Also, what other extensions do you have installed?
Do you use a custom template model (if so, what’s in it)?
Konstantin
According to the dev team the issue might be caused by a corrupted installation as well.
I’d recommend you try just reinstalling first.
Reinstall worked! Thank you. I always love seeing new toys in an update!!!
OK, that’s a relief.
I hope you’ll like the new stuff in 7.3.
Please share feedback and improvement ideas.
