I’m with a texture issue with the lathe modifier, it makes the texture separated by each triangular face, not like a single model when I try to render this table. The first image is the model view, which is right, and it supose to be the same when rendering but it’s not. Does someone knows how to fix it?
This seems to be a general 3ds Max question, not Corona-specific, but check out the Corona Triplanar map - you may find it useful in many applications: Corona for 3ds Max
Are you using procedural textures? If so then use Explicit Mapping type from the Coordinates tab. Scale doesnt match the viewport when using ObjectXYZ.
