Anyone else having issues with Laubwerk plants rendering without materials again?
YES! leaf’s Alpha not working in CPU nor GPU
When disabling Linear workflow is Ok but gamma is brightening the whole thing
Could you please advise what version of the Laubwerk plugin you’re using?
On the Laubwerk site it says it’s not yet compatible with Vray 3.6…
Not yet indeed. The issue you described has a workaround for now - simply select the relevant multi-material (plantname_mtl) and apply it to the proxy component.
This one, however, I cannot reproduce. Any info (illustrations, packet sample scene) would be appreciated!
Kind regards,
Peter
Test this. [quote=“noel.warren, post:4, topic:85719, username:noel.warren”]
It seems 3.6 breaks compatibility with Skatter. We will address this in 3.60.02. As a temporary workaround, open the ruby console and copy and paste the following one liner
class VRay::LiveScene::Mesh;def material;get_material(nil);end;end
This has to be done once for each SketchUp session
Sorry for the inconvenience
[/quote]
Amazing Laubwerk Plugin works again. There is a new plugin release 1.0.25 included in laubwerk plants kit freebie. I’ve tested it with VfS 3.6 on both SU 2017 and SU2018.
Regards.
