Laubwerk Plants Vray 7 Sketchup
Greetings,
Is there any action on behalf of Chaosgroup to be taken on the Laubwerk Plant texture issue as described in the link below?
thank you in advance
Hello @ARTCH ,
Currently Laubwerk are working on adding support for V-Ray 7. Please refer to my colleague’s post in this thread.
Kind regards,
Iva
Thank you very much.
Regards
Update…
Is there any news on the progress of Laubwerk plants’ compatibility with Vray 7?
Unfortunately it is very difficult to find any information on the web about the new version, which according to the information here was supposed to be available within a few… weeks.
I would be very grateful for any information.
I believe I am not the only one.
Thank you in advance and best regards.​
You are definitely not the only one, having this issue as well… for weeks!
The same Laubwerk Plants models work well in Rhino 8 and Vray 7. Within SU 2024/2025 with Vray 7.001/7.002 they do not.
Globe Plants issue as well:
Hi everybody,
We have just released V-Ray 7, hotfix 3 for SketchUp - addressing the described problem.
Note that if you have already saved a project using V-Ray 7, the Lubwerk assets will remain gray.
If, however, you perform a Laubwerk import in the new version, the asset should render as expected.
Regards,
Konstantin
Laubwerk doesn’t work with the latest version of Vray (V-Ray 7 for SketchUp, update 1​) and sketchup 2025, we have to download this version V-Ray 7 for SketchUp, hotfix 3.
Hello @pierre_audouin ​!
As mentioned in the following forum thread, Laubwerk’s compatibility with our official V-Ray 7.10 version needs to be fixed from Laubwerk’s side.
As a workaround, you can paste this snippet in the SketchUp’s Ruby console before activating V-Ray​:
module VRay; def self.has_gui_license?; true; end; end;
After a render is started, the newly added Laubwerk assets will become visible also in the Asset Editor’s Geometries section.​
I hope it helps.
Regards,
Ivelina
Greetings,
After fixing the issue in Vray 7, the problem reappeared after updating to Vray Sketchup 7.2.
If I remember correctly, the issue was fixed in Vray, not Laubwerk.
(From the forum above:
fleawig
Mar 31
Just FYI, for anyone following this: the recent V-Ray 7 Hotfix 3 update fixed this issue with the BRDFDiffuse layer. You should be able to use Laubwerk plants now with V-Ray 7.)
Please provide information regarding SU 2025/26, Vray 7.2, and Laubwerk Player.
The problem is the lack of textures.
Thank you in advance.
Hello artur_chojnacki,
Keep in mind that Laubwerk needs to be installed for the given SketchUp version in order for the workaround to work. I retested the workaround with the new V-Ray 7, Update 2.1 and it still works.
I confirmed with Maxon that there is currently no official Laubwerk support for SketchUp 2025 and 2026.
Kind regards,
Iva
Thank you,
What should I understand by workaround?
You are referring to the following:
Code:
After a render is started, the newly added Laubwerk assets will become visible also in the Asset Editor’s Geometries section?
I would like to point out that for some time, probably until some update, the V-Ray Laubwerk Player worked efficiently in SketchUp 2025.
I simply copied the plugin from the previous version, when installation was possible.
In my opinion, this is a complete disregard for the customer on the part of Laubwerk, considering the rather costly investment in the models.
I would be grateful for any guidance and clarification regarding the following statement:
Hello artur_chojnacki ,
Yes, this is what I meant. Copy pasting this snippet into the Ruby console and starting Render downloads the Laubwerk Assets (given that Laubwerk is installed for this SketchUp version):
I verified this workaround is still working with V-Ray 7, Update 2 and 2.1.
Kind regards,
Iva
I do thank you very much.
