I would like to simulate a lava flow like this reference. https://www.youtube.com/watch?v=HzwuTBx93uA
Any tip for a start?
Cheers
Cheers
The lava from this reference video looks pretty steady flowing. What you can do is start with the Tap Water preset and adjust the discharge for the emitter object.Depending on the look you’re after you could add a little viscosity. Then for the rendering you can apply VRayLight material to the liquid and it should be pretty close.
You could get the smoothness by increasing the Steps per frame as well - this will slow the sim down proportionally as well.
Perhaps try turning viscosity and non-newtonian up? Like a chocolate sim?
Produce it with two different simulations. One to get the flow and the “fall” of the lava just right, and then another one just to get the splash. When composited together it should be nice.
Thanks for your tips. I wonder if Phoenix has something like killplane in Bifrost. so you can kill the fluid where you want it to.
Yup, in the right-click Phoenix props of each geometry you can enable ‘Clear Inside’ and it will kill the particles or grid channels from the list. However, note that the geometry must be inside the simulator.
Roger that, gonna check it and get back to you.
Seems like everything’s fine on my side. Are you using nParticles? You just have to connect the nParticle system to the Phoenix source and it should work. What kind of issues do you have?
