I wonder if it’s possible to add the vray object properties dialogue to the layer manager when you right click a layer or object in layer manager. Is this scriptable?
And wouldn’t it be nice to add an alternate material column to the layer manager with a checkbox next to it to enable / disable, where you could drag and drop materials to / from the material editor. This way you could setup a default layer<->vray material structure. Is this scriptable, or do you need the sdk?
Thanks,
Ivan
