Layer shader with triplanar textures doesn't work in bump channel
Hi!
When I plug textures with triplanar projection into a layer shader and try to use the resulting texture as a bump map, it doesn’t work - the bump doesn’t show up. The triplanar + layer shader combo works fine in other channels, only bump seems to be affected.
I’m on Win 10, C4D R18, Corona Beta 2 stable.
Cheers
Hi, thanks for the report. I can also confirm this and will make a note of it. Thanks :wink:
