Layered material invisible in viewport
I installed 1.3 and was just checking out new corona layered material.. not sure if i am doing anything wrong.. but nun of the layered materials can been seen in view port or even their masks.. with show shaded material button on.. Any input on this? thanks..
I gues that only the base material could be shown at the wivport as long as there is no swich as in default blend mtl
This is known: Corona Layered material problem - Corona for 3ds Max :: Issues - Chaos Forum
okie.. got it.. thanks.. kinda hard to do uvw channel mapping unless u have IR running..
Is there any way to disable error message window? kinda annoying :confused:
Thanks :smiley:
Error messages - you can just press the “ignore similar” button.
Show map in viewport - you can clone the material into an empty slot and then assign this material to the object.
I was able to completely suppress CEM window, but decided not to go this way - it is better to fix all errors and warnings in a scene than suffer from some serious performance problems in fullish bliss :] But i agree that sometimes CEM window can be really annoying, i hope that in the future devs will find a way to make this thing less intrusional.
Quick idea: nesting the error messages inside a tab in CVFB.
I’d like to see this implemented, but there is some catch.
  • there is not so much space, especially horizontaly, so it could be very crowded and inconvenient to read.
  • what if tools in VFB is closed? Errors would slip unnoticed.
let’s continue with the brainstorm…
it could be an icon which gets highlighted if an error/warning is detected, the window pops up only if you click that icon
That could work. Don’t forget to register your idea on mantis - i’m pretty sure many would welcome such an improvement :]
ok, but let’s continue with the brainstorm here :smiley:
I can already see one drawback of the “button” version: some users could not notice it (unless it’s very apparent) and ignore the error. Having a huge error message jump into your face could save some support nerves. :wink:
Just give a check box user system tab which says show/hide error message box :smiley:
Nope. As Romullus mentioned, the errors cannot go unnoticed.
What if i want to ignore all errors? It should be up to users if they want error box visible or not :smiley:
Lets see i have few assets in scene which are missing maps.. and that asset is off camera.. so i dont care about those missing maps.. in this case why would i wanna see error box?
Sure, and let the devs devote all their time and energy to solving all those false bug reportings in forum ;]
You can tell to Corona what type of mesages should be ignored.
Currently you can press “ignore similar errors”, and I had an idea with a button which informs about them.
any layered mtl submap can now be displayed in viewport
