I’m creating a simple material for a product (candy bag) using the Corona Layered Material. I’ve created a “Base material” using the color map and some other channels and I’ve then added a “silver foil” material for the 1st slot in the Layered material.. I’m then using a black/white alpha (PNG texture) in the “mask slot”.. it renders OK, but the silver foil material i off-set.. it’s not rendering perfectly aligned on top of the color map? Why is this?
When I tried to re-create the whole material, just using a single Corona material, then the same “silver foil” alpha texture renders prefectly aligned… Is there something I’m missing in the settings for the Layered material or why is it not aligned correctly?
Thanks,
Frederik
