We’ve already purchased several copies of Vray 5 for the studio to begin the transition.
I’m working on transferring some client materials to 5 and couldn’t figure out how to do so in the new blend material. Maybe you could help point me in the right direction?
I was using a texture map to drive the scratch material reveal on the edges. If you need me to I can provide the file to you.
You could try the VrayCurvature map, which may work better, as there are wireframe artifacts with the dirt it looks like.
Use it as the mask in the mask map, with e.g. noise as the rough map.
