Layers dissapearing
Hi
I have model half built , and when I used the converter it makes all the layer disappear, and the objects are still there.
Any idea
screen grab attached
I can send the file to Corona if needed.
Thank you
that doesnt look like the layer window. The layer window icon is not even highlighted blue.
do they show up if you click this icon?
Thanks for the reply.
No thats doesn’t work either.
Strange goingings on.
Opened up an older version of the file and all the layers are there.
So just to be clear.
Max 2016_SP1 Corona 1.3.
I have SP2 but the object issue is nuts , it flips and moves around the work space.
I just checked and this shouldn’t happen. I placed some objects on different layers and used the converter. Which version of the converter did you use? Are you able to reproduce this?
I downloaded V1.24
I can send the file to you if you want.
Can you email me please.
It’s a current project in progress.
Thank you
philip
You can send a support ticket here: https://coronarenderer.freshdesk.com/support/tickets/new
I will check it.
I have sent it in thank you
philip
