Layers in new VFB
how can I add an Extra texture in new vray 5 in VFB?
I have it as a render element, but I would like to add it (multiply) to the RGB channel, like in the PS.
Also, I would like to manipulate reflections and specular channels as well… is this possible?
Hi @fprpic
You will need to set your Source layer to Composite, add your RGB and then add any subsequent Render Element (be it ExtraTexture, Reflection, Specular, etc.)
You can then choose a Blend Mode (i.e., Multiply as you’ve suggested) and play with the Opacity/Multiplier values. See the following recording for better visual explanation: http://ftp.chaosgroup.com/support/sc…6_10-29-23.gif
Refer to the following forum post to read more about the new V-Ray Frame Buffer and its features: https://forums.chaosgroup.com/forum/…25#post1091325
Nice, thanks!
