Layers in Vray Framebuffer
I´ve seen that, when cloning the vfb window, there is a layer paremeter. Is that the same as render layers in maya where you can switch between renderings (very usefull, I hope it´s the same thing..)?
Nope, it’s the same Layer button that you get with the 3dsmax VFB and it shows you the different layers of a multi-layered GBuffer.
The render history as it is in Maya is already in implemented in the VFB, but it’s currently not enabled; it may make in some of the next builds.
Ok. I hope it will be enabled in the next build. It´s something I have wished for since I began rendering..
