LC Map not loading correctly
I was curious if anyone has experience this before, I never have. it’s very odd, I rendered the scene with IR/LC and the LC map appeared to render ok, without visible issues but when the saved maps are loaded in and you render the scene, it looks like the lights are off. The reason I know it is not the IR map is I ran a test with the saved IR map and set the LC to single frame, not using the saved LC map, and tested one frame…rendered ok. I have attempted to render several cameras in the scene with the same results so perhaps it is related to this file…just can’t figure it out. I even merged the file into a fresh scene…same result.
Any help would be appreciated…
Thx…Scott
Is it possible to send us the test scene with the exact steps to reproduce the issue.
You could write us at support@chaosgroup.com and share your scene. Please include the link from this forum thread.
