Hi Guys,
have tried a blue hour render, textured with substance painter.
Nice idea, love the colors and the overall looks but the textures definitely need some polishing. You need to fix some of the texture mapping and try to implement some higher quality textures (higher res), oh and your bump amount is also over the top.
Other then that, keep up the good work ![]()
Thanks, you are right, although textures are 4k, however have lowered the diffuse blur value way too much and like you said the bump is high on top of that i had give a sharpen filter on the base color in substance and thus the overkill in bump. thanks for your honest opinion.
