OK I have had this issue before but seems to be happing again and not sure why this time.
The image shows leaf 1, and seems fine but when I turn over leaf 2 is rendered with the inside black.
The psd texture file does have an alpha and eve if i plug in a simple black and white image into the opacity slot i still get this result.
Could someone confirm this or suggest an alternative approach?
It seems like a bug. While we’re working to fix it I could suggest the following workaround, see the attached files (leaf_01.ma).
For some reason the opacity connection doesn’t render correctly, so I’ve created a BRDFVrayMtl, dropped in the two files and I’ve used the original material as a shadow override. (The brdfVrayMtl is created in create > vray > create from vray plugin > brdf).
I’ll let you know when we have this fixed.
Just a quick question - last time when you had this issue - were you using psd files? leaf_01.zip (157 KB)
Not yet. There is more pressing matter that we’re attending to but we’ll try and fix that as soon as possible. I’ll update this thread when this is fixed.
