Goodmorning!!!
I want to make a leaf material any suggestions???
Thank’s!!
Hi, there is a post somewhere on this forum abouts leaves and grass.
Have look for it.
cheers
belly
Thank’s but is referred to grass with Vray material…
With Vray is full of nice tutorials about leaves… i was hopping to find something like that…
There was a thread about leaves somewhere. Generally: plug a diffuse map, you can also use original or altered version of this map for translucency, give it some translucency fraction, then add a bump map and a little reflectivity. Remember that in Corona you should be as close to reality as possible so it will be best to use reflectivity amount and glossiness < 1.
Thank’s Maru!!! i’ll give it a shot…
there is some leaf material in this tutorial
http://www.evermotion.org/tutorials/show/8334/making-of-small-living-room
Thank you very much! Nice share. Specialy the GrowFX setups really helpfull to me.
Keep rockin’ pal ! ![]()
