Leaf shader and some lighting styles
Only tests, rendering with fog few seconds on one 5960x, so some noise is there of course. But still pretty good quality and very quick even with fog.
a few seconds? How does it compare to your gtx1080?
I mean less then one minute if I dont count first initialization.
I cant try it with GeForce because dont have latest Forest Pack. But I have only one 1080 with three displays and one tv atached, so it will be slower then graphic card used to rendering only.
Looking great. Does the tree leaf have the same shader as the plants?
No, shader is different here. Just trying some mood with lighting and fog.
Looking great! I would add some contrast though. The shadows/dark areas are too washed out in my opinion.
I do this in purpose, there is fog. When I remove it, it has more contrast, but I wanna add little bit of atmosphere.
Can you give a hint on the way you are developing this?
FastSSS or Vray2Sided? Is it pure geometry leaves or one-sided planes with opacity map?
Its VRay2sided with opacity and normal map.
And one sided planes.
