Hi, this is one of my sofa models i did before, rendered with Corona.
PT+PT 4-10
Rendertime for each one : 2H
no post only removing some few noise on shadows.
Great model! Great render!
Well, only 2 hours a lot;)
Great render !
Smooth. ![]()
Maybe some more detail /shader work is needed to the pad to be on par with the rest.
Thanks guys .
It’s pretty cool
Maybe it could be better some additional details on the wrinkles seen on the front and also textures that would give it a little more worn look cause the leather really looks just too perfect to me. And also the material on the pillow looks a little weird. But still very nice and good modeling work, did you use only max and traditional poly-modeling or did you sculpt out stuff using zbrush/mudbox? Overall I’m curious how much time you spent modeling this cause I’m experimenting doing all sorts of models using just sculpting and in the end it’s so far the same/slooow process (timewise…)
How long does it take to create such model?
Hi lacilaci glad you like it, i agree with your remarks i didn’t use zbrush for that one to bring out the wrinkles and the pillows are just speed stuff ive added to the sofa.
It was done only with poly modelling in max in about if i remember well 4 hours, i’ve started it by using a simple box and extrude the curved side of the sofa by spline and i’ve inverse the edges to extrude them to have that nice look, the more time you give it the more it looks correct, sometimes i spend a whole day for one sofa ( zbrush + marvelous designer are used+ revising it in max so you can imagine the tweaks and tests etc )
great collection and modellings skills ondrike, waiting for your renders !
About 4 hours for that model i think maybe more because i revise/edit a lot my models before deciding
